    Code airbag 02 Juil 2010 22:28 #130963
    • Dodprobe
    • Portrait de Dodprobe Auteur du sujet
    Bonjour
    qui pourais medonner la liste des codes erreur car actuelment sur ma titine il clignote 5 fois et aprés une fois et cela ce réppette tou le temp avez vous une idée merci et a plus
    Re: Code airbag 03 Juil 2010 07:35 #130965
    Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
    | -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
    | 12 Low Battery Voltage
    | 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
    | 21 Safing Sensor - Not Mounted on Vehicle Properly
    | 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
    | 23 Safing Sensor Input Feed/Return Circuit Open
    | 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
    | 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
    | 33 Pin 7 Not Grounded at Diagnostic Monitor
    | 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
    | 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
    | 41 Crash Sensor Circuit - High Resistance or Open
    | 44 RH Crash Sensor - Not Mounted to Vehicle Properly
    | 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
    | 46 LH Crash Sensor - Not Mounted to Vehicle Properly
    | 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
    | 52 Backup Power Supply - Voltage Boost Fault
    | 53 Internal Diagnostic Monitor Fault
    Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
    Nous avons 312 invités et un membre en ligne
