Code airbag 02 Juil 2010 22:28 #130963
  • Dodprobe
  • Portrait de Dodprobe Auteur du sujet
Bonjour
qui pourais medonner la liste des codes erreur car actuelment sur ma titine il clignote 5 fois et aprés une fois et cela ce réppette tou le temp avez vous une idée merci et a plus
Re: Code airbag 03 Juil 2010 07:35 #130965
Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
| -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
| 12 Low Battery Voltage
| 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
| 21 Safing Sensor - Not Mounted on Vehicle Properly
| 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
| 23 Safing Sensor Input Feed/Return Circuit Open
| 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
| 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
| 33 Pin 7 Not Grounded at Diagnostic Monitor
| 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
| 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
| 41 Crash Sensor Circuit - High Resistance or Open
| 44 RH Crash Sensor - Not Mounted to Vehicle Properly
| 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
| 46 LH Crash Sensor - Not Mounted to Vehicle Properly
| 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
| 52 Backup Power Supply - Voltage Boost Fault
| 53 Internal Diagnostic Monitor Fault
Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
