    lexique des abreviations 17 Avr 2011 22:26 #141236
    A
    AAC => Arbre A Came
    AAi =>Avance Allumage Initial
    ABS =>Anti Blocking System
    A/C => Air conditioné
    ACD => Acitve Center Differential
    AFR => Air Fuel Ratio
    AOA => Avance Ouverture Admission
    ASC => Anti Skid Control
    ATR => Accord Type R
    ATTESA-ETS=> Advanced Total Traction Engineering System for All - Electronic Torque Split
    ATTS => Active Torque Transfer System
    AWS => All Wheel Switch
    AYC => Active Yaw Control
    B
    BAR => Barre Anti Roulis => Barre Anti Rapprochement
    BD => Barre stabilisatrice arrière déconnectable
    BMI => Best Motoring International
    BOV => Blow Off Valve
    BVA => Boite de Vitesse Automatique
    C
    CAI => Cold Air Intake
    CMS => Système d'atténuation de collision
    CRX => Civic Racing Xperimental / Civic Renaissance Xperimental
    CTR => Civic Type R
    D
    D4-D => Diesel injection directe avec common rail
    DA => Direction Assistée => Départ Arreté
    DI-D => Diesel Injection Direct - Pas de common rail
    DITD => Direct Injection Turbo Diesel
    DOHC => Dual OverHead Camshaft
    DP => Pompes jumelées (dual pomps) avant et arrière (Awd)
    DPNR => Diesel Particulate NOX Reduction.
    E
    ECU => Electronique Controled Unit (et non pas Engine, en effet il y a des ECU d'air bag et de clim, ou meme d'abs..
    EAV => Ecrou AntiVol
    EBAC => Assistance au frein moteur
    EDFC => Electronique Damper Force Control
    EFI => Electronic Fuel Injection
    EGR => Exhaust Gas Recirculation
    EGT => Exhaust Gaz Temperatur
    EMS => Engine Managment System
    ESP =>Electronic Stability Program
    F
    FDR => Final Drive Ratio
    FF => Front Front
    FIMC => Front Mount Intercooler
    FMU => Fuel Managment Unit
    FPR =>Fuel Pressure Regulator
    G
    GDI => Gazoline Direct Injection (Injection Direct d'Essence)
    H
    HB => Hatchback
    HID => high intensity discharge
    HICAS => Hight Capacity Actively Controlled Steering
    I
    i-CTDi => Injection Diesel rampe commune et turbo variable
    IC => Intercooler
    IG => Ignition
    IDC => Injectors Duty Cycle
    IDSI => Intelligent Dual System Ignition
    ITB => Individual Throttle Body
    ITR => Integra Type R
    i-VTEC => Intellegent Variable valve Timing and Lift Electronic Control
    J
    JA => Jante Alliage
    JDM => Japan Domestic Market
    K
    KAD => Kit d'Admission Direct
    L
    LDR => Liquide De Refroidissement
    LHD => Left Hand Drive
    LSD => Limited Slip Diferentiel tial ??
    M
    MAF => Mass Air Flow
    MAP => Manifoild Air (absolut) Pressure
    MASC => Contrôle de motricité et Contrôle de stabilité
    MTF => Manual Transmision Fluid
    MON => Motor Octane Number
    N
    N/A => Naturaly aspirated
    NBAS => Nissan Brake Assist System
    N-CVT => Nissan Constant Variation Transmission
    NSX => New Sport Xperimental
    O
    OBD => On Board Diagnostic
    OEM => Orignal Equipment Manufacturer (souvent parts apres, pieces d'origine quoi) contraire d'aftermarket
    P
    PGM-Fi => Programmed Fuel Injection
    PMB => Point Mort bas [Bottom Dead Center BTC)
    PMH =>Point Mort Haut (Top Dead Center TDC)
    PS => Power Steering / Direction assisté
    R
    REF => Répartition électronique du freinage
    RFA =>Retard Fermeture Admission
    RFE => Retard Fermeture Echappement
    RFE =>Retard Fermeture Admission
    RHD => Right Hand Drive
    RON => Research Octane Number
    RPM => Revolution per Minuts ??
    RTP => Real Time Programing
    RWD => Rear Wheel Drive
    S
    SAFC => Super Air Flow Converter
    SB => Silent bloc
    SC => SuperCharged
    SOHC => Single overhead camshaft
    SSelect => Super Select - 4x2, 4x4 variable, 4x4 bloqué
    SSQV => Super Sequential (blowoff) Valves
    STD => Standard
    STI => Subaru Technica International
    T
    TE => Train épicycloïdal avec blocage
    TEIN => TEchnical INdustry
    U
    UEGO => Universal Exhaust Gas Oxygen sensor
    USDM => US Domestic Market
    V
    VAFC =>Vtec Air Flow Converter
    VDI => Diesel injection. (Le V, dixit Nissan, ne veut rien dire. Turbo injection directe)
    VEC => Valve Exhaust control
    VTEC => Variable valve Timing and Lift Electronic Control
    VVTi => Variable Valve Timming inteligent
    VVTL-i => Variable Valve Timing & Lift - Intelligent
    W
    WOT=>wide open throttle
    Y
    YRV =>Young Recreative Vehicule
    sources prise via le site " japan car ", merci au modo : Rb26dettvs2jzgte ;)
